trying to create a angled tube from base
nelson_pereira280
Member Posts: 36 ✭
Hi all,
i dont know how to produce this. I need to make a tube from the top base (plane2) to plane 3 at a 45degree angle part or the base (add extrusion).
How can this be done?
the link:https://cad.onshape.com/documents/56be432aff0f3507a1521f2e/w/f2b8510679b9293e1e2d2322/e/1d4c80942863a16daf807075?renderMode=0&uiState=65ecdfc4e963876350675136
Optionsrobert_scott_jr_ Member Posts: 326 ✭✭✭Threads look ok. What's the issue? Extrude 3 looks better if Up To Face is used instead of Up To Next.0
https://cad.onshape.com/documents/1902cbcb36d961ae5f0914df/w/c69fe9daad423c9f5be813da/e/0144b1801974331cfe2cab28
now i need to make a thread (M6) to this tube but the thread creator wont let me pick the inner part. is it because the script doesn't work? I tried multiple scripts....
https://cad.onshape.com/documents/56be432aff0f3507a1521f2e/w/f2b8510679b9293e1e2d2322/e/1d4c80942863a16daf807075?renderMode=0&uiState=65edc282a3251d42d035c446
I don't want to have to create the thread manually.
https://cad.onshape.com/documents/56be432aff0f3507a1521f2e/w/f2b8510679b9293e1e2d2322/e/1d4c80942863a16daf807075?renderMode=0&uiState=65ee46a987fdb409407bfee1
https://cad.onshape.com/documents/56be432aff0f3507a1521f2e/w/f2b8510679b9293e1e2d2322/e/1d4c80942863a16daf807075?renderMode=0&uiState=65efa50bf8f7a4450010ba7f
The hole at the bottom of the part shows in the sketch but when printing the part in 3D, it doesn't. What could be the problem?
