Projected curves with complex intersections - how to achieve a sweep?
chris_thornborrowchris_thornborrow Member Posts: 6
edited February 2024 in Community Support
Hello folks,
I am a beginner at Onshape and its my first post. I have searched the forums and web but to no avail. I hope someone can help.
As you see I have a vase like object onto which I have projected dxf imported curves from inkscape. My goal is to have the curves become the 3d paths for a sweep for the little triangle on the right (3mm base).
I wrote a simple test file on a sphere using a projected curve but of course I did not self intersect the curves before proceeding. Now I've spent many many hours and there are hundreds of curves here- I simply cant do each one by hand. Worse, they are designed to intersect (which I discovered this evening is not supported in Onshape) so I cant just do them all together. Can anyone help? Is there a feature script to go through each curve one at a time maybe?
https://cad.onshape.com/documents/6de887b538ee1a30cdd4481c/w/3cfe0f8c6a49e42a85b5abdc/e/8402d9dafc501dca890fcf47
Failing this does anyone know Fusion360 and (if I learn that) could this be done in 360?
Yours, a little desperately,
Chris
(ps note the curves and profiles are on the inside surfaces of the vase -deliberately).
  • chris_thornborrowchris_thornborrow Member Posts: 6
    Well it seems there are no obvious answers to this problem. I have tried using split on the original sketches of the imported dxfs at each crossing of two curves and then trying sweep, but again it fails.
    The only ray of hope is that dxfs are imported as seperate splines and so IN THEORY if I could write a featurescript that iterated through each curve, called opsweep and applied a boolean union or each curve. I suspect it would be very slow to build. Looking through the standard library sweep.fs, it seems iterating over the curves could be done with simple code changes but Im stuck on how to move the sketch profile to the start of each curve. Can anyone help?
  • STEGSTEG Member, User Group Leader Posts: 136 PRO
    Hi,
    Have you tired to positions the profile to sweep to intersect with the path?
  • john_lopez363john_lopez363 Member Posts: 137 ✭✭✭
    edited March 2024
    @chris_thornborrow
    It's a bit tedious...and not absolutely perfect (also for simplicity sake i used a circle as the Sweep Profile instead of the triangle you will need), but with a little tweaking you should be able to get it to work.
    1) You only need to Sketch and Project one set each of the scroll pattern.
    2) This approach solves the intersecting paths issue.
    3) All of the Sweep Profiles sketches were add by using MateConnector option, and then adjusting for necessary correction in an attempt to get the sketch normal to the sweep path (again not perfect, but close)
    4) Circular Pattern is using Feature pattern operator
    Link to follow along:
    https://cad.onshape.com/documents/68f9dc1fa9737f8c8b9d927e/w/2170014a43be42f82320b7c8/e/7aa018facd090ebaf9c127f4
