cut with a surface
don_howedon_howe Member Posts: 136 ✭✭✭
edited September 2015 in Community Support
is it possible to cut with a surface? I tried the thicken option but couldn't get enough thickness to cut the part
https://cad.onshape.com/documents/71f32dc45abd4884aa76c045/w/61c0ec2dae48406080ccef39/e/b4a44f50708e4d3488d143c0
  • don_howedon_howe Member Posts: 136 ✭✭✭
    Thanks that's what I needed. I was trying to do it with extrude and thicken.
    I could only choose 1 surface to split the part and was unable to select both. Therefore I went ahead and thickened your surfaces a did Boolean subtract then hide the remaining piece.
     https://cad.onshape.com/documents/0b426828b6474c78909a6732/w/1e084a4936e341c8af91ebc5/e/27d9514be44a467eb22e9ed0
    At present we cannot knit surfaces in Onshape.
    The only way I'm aware of to create surface knits is to model them in a single feature.
    I was able to create a loft and then I used the split part option, essentially trimming the part. Now if I could only do a variable radius.
  • pat_kelemenpat_kelemen Member Posts: 1 ✭✭
    A separate topic, but something I had to find out today (and would have been helpful to know generally). The fill feature will automatically knit a surface body to create a solid (if all surfaces of the knit are selected to create the fill surface).
    If you have geometry where that's not the case, but have a group of surfaces that could create a closed body, the union feature can be used to create a knit (or, create a solid from the group of surfaces).
    It's possible these features were not an option at the time of the creation of this thread, but for anybody trying to knit like how SolidWorks allows, these features will be the equivalent of what you would use.
  • S1monS1mon Member Posts: 3,773 PRO
    This thread is ancient (in Onshape releases). As you say the Boolean union feature will knit surfaces, and there's also mutual trim now too.
