What does "sketch curves to extrude" mean??
marc_cawood
Member Posts: 6 ✭
So I'm battling to split a part which I want to print in two colors.
I guess I need a surface (in my case a cylinder) to separate my solid cylinder into two parts but I am unable to generate any kind of surface extrusion.
If I try to extrude a circle into a cylinder I select my line sketch and then extrude -> Surface onshape just shows "sketch curves to extrude" (in blue and green - which sounds better than red) but does not extrude at all and I am unable to proceed. If I click OK nothing happens.
Same thin if I try to extrude a simple line into a plane (see pic).
NeilCooke
Moderator, Onshape Employees Posts: 5,969
You are selecting the entire sketch from the feature list. You must pick the curves from the screen.Senior Director, Technical Services, EMEA5
I would if I could. No matter what I do I cannot seem to select it. The only time my circle sketch is even visible is when I edit it.
Perhaps because it's coincident with the part? I don't know but I can't click it at all
https://cad.onshape.com/documents/8dbea644c0474fabd876836b/w/4a15ff5feb6376378b767140/e/011481b323d11188c9367154
Is there any altternative to clicking on the drawing? Like a list? Or any way to hide parts?
I imagine it wants to know in which direction to extrude but read somewhere this is always/usually normal to the sketch plane...
I was then able to select the circle and extrude it.
Weird.
