Circular Transition
martin_kopplowmartin_kopplow Member Posts: 834 PRO
edited March 2024 in Using Onshape
I have a seemingly simple problem. I want to create a smooth transition between the 2 slabs. It is to be tangential at the start and end profiles, and that is easy so far. But I also want it to be circular in the plan form. Now, I could play with the start and end magnitude of the loft, until I get pretty close, but this provides little control, modifies the slope at the same time, and then I'd like a precise method, one I could reproduce exactly each time, and possibly also make configurable later.
Any ideas (except for replace face, which does neither work nor is it precise) for this simple one?
