I'm in much the same boat (pun intended) as @david_sohlstrom and hoping that Onshape will see a place for a middle tier once the product is established financially. Onshape will get used for small throwaway projects until then and my license of Geomagic Design will get relied on for the larger projects.
And another note, I truly understand if you shun the idea of bouncing between pro/free - Geomagic has currently better tool set and works like a charm installed locally. I don't like the 'new' GD on/off licensing system, but I completely understand why they don't give 3 or 5 licenses anymore - it's because users betrayed them by not keeping licenses personal as they were intended. This is why I don't believe in the idea that companies would have more licenses if they were cheaper.
The part of my quote after the last comma is intended to restrict the scope of the hypothetical revenue contraction to a specific group of businesses, not described in the quote, but described in the post the quote is drawn from.
I'm trying to present a counterargument to the one which you make afresh on behalf of those who "wouldn't pay for the pro license at all", because (if correct) it presents a serious stumbling block, which (I'm suggesting) cannot simply be wished away, but must instead be addressed if there's to be any hope of persuading Onshape of the merits of your case.
