How to fill holes ?
frank_soe
Member Posts: 4 ✭
I am trying to fill the holes as seen on the arrows in the picture. I have tried different methods fill/sketch the circular patterns.
Guidance is greatly appreciated
Matt_Shields
Member, Onshape Employees Posts: 789 PRO
Not sure, but it sounds like you want that all to be one part? Use Add instead of New when making the little posts.1 -
matthew_stacy
Member Posts: 489 PRO
@frank_soe, weren't those four holes created in sketch1? You might be swimming upstream. Why not just edit sketch1 so there are no holes to fill?
