export part of a part?
scott_depacescott_depace Member Posts: 9
I have a part that I have made which is slightly too big for my 3d printer. I want to print pieces of the part individually and put them together later. One of my extrusions uses the "up to face" end type. If I wanted to print the extrusion without the face that it goes up to, is that possible? I want to export "tube 1 and 2" as 1 part but nothing else.
https://cad.onshape.com/documents/9d4dfc3011411781aefed6de/w/3bbc81976dac2e28283e1ee0/e/86de8b1bdd991074ac00aa07?renderMode=0&uiState=65fb551c8b11fb508f30fdb4
thanks
  • eric_pestyeric_pesty Member Posts: 2,396 PRO
    I think you need to do a part split, then print both parts separately.
    It might be a good idea to add geometry where the parts connect to each other to make sure they join well
