Cut an assembly
robert_scott_jr_robert_scott_jr_ Member Posts: 744 ✭✭✭
For a clockface I have made a weave of oak strips. One strip of the weave was modeled in a part studio and then mirrored to create a like strip. The two strips' wide faces to eventually be fastened 90 degrees to each other. I modeled each opposing weave in assemblies and the married them together in another assembly. The shape and other features of the clock's frame is not yet decided. I would like to be able to cut out shapes from the married assembly to use in different frame configurations. Alas, no boolean or split in an assembly. Is there a work around for this or must I create the entire weave in a part studio? - Scotty
https://cad.onshape.com/documents/d88c835daead1b6b03142a47/w/d12c0623662d6fc6ddabd048/e/24461b925321f0f68dbb3f74
  • robert_scott_jr_robert_scott_jr_ Member Posts: 744 ✭✭✭
    I did go back to create the entire weave in a part studio. If there is one, please post an alternative. - Scotty
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,058 PRO
    In-context editing is what you are looking for. Here is the training course for it in the learning center. (Free for all users):
    https://learn.onshape.com/learn/course/managed-in-context-design/introduction-to-managed-in-context-workflows/what-is-managed-in-context-design
    Yes, I've used in context editing previously but I don't think it applies to a group since I'm not able to select that option. I suppose I could assemble individual strips of the weave using a sketch or a mate connector pattern to get all the parts positioned and edit them one by one but that begs an easier way. Thanks for responding. - Scotty
  • wayne_sauderwayne_sauder Member, csevp Posts: 639 PRO
    edited March 2024
    @robert_scott_jr_
     The only way to use context editing (it is hardly true context editing) is to start a new in-context part studio from your assembly, window select all the parts and transform-copy them, then cut away. This is very messy (creates copies of all parts) but it can help to get where you need to be and harness the power of assemblies.
  • test_user242test_user242 Member Posts: 9
    Are Onshape intending a proper fix for this that doesn't involve messy copying of parts? It seems quite a basic feature that's missing from the program to me from past experience. (Think e.g. machining bearing journals installed at each end of a housing in one machining op to maintain correct runout as a pair). If somebody could link me to a feature improvement request I'd happily upvote it.
