Linear Pattern Problems
I'm doing "Intro to CAD 3.1-3.4" and I'm on step 5 of 3.3, which tells me to snap one brick onto a plate. It shows that I have to drag the bottom mate connectors, however I cannot see the mate connectors no matter what I do (yes, I pressed K several times and it hasn't worked). I go back to 3.1 step 12 microstep 12 and I come across this:
I go back to the part studio and I check the linear pattern I made. This is what I find:
There's no "Apply per instance"! What's going on?! I've tried everything! Not even my teacher knows what to do!
If the seed one is also missing make sure the "owner" of the MC is set to the part (this is also a fairly new change that might not be mentioned)
Can you share a link?
sorry for the massive screen shot, my brains fried. but what Eric mentioned is right here in your initial Mate connector feature, youll want to click into the "select owner entity" box and then select either select the part in the graphic, or just from the parts tree. took me minute
NOTE: I'm no longer in engineering class, so this is not only outdated but is also most likely never going to be used again. Thank you to everyone who helped me out. Danke und tschüsse.
