Adding an Isometric View within a drawing
Jonathan_28Jonathan_28 Member Posts: 3
I am sorry if this has been covered elsewhere but I searched and I couldn't seem to find an answer.
When you make a drawing from a Part (right click) you get the standard four views. However if you start with a blank drawing template and want to add views  - how can you add an isometric  view? All the other standard options are on the view list but isometric -  it is a little odd as it is available when you create directly from a part file.
Any help would be appreciated.
  • navnav Member Posts: 258 ✭✭✭✭
    Hi @Jonathan_28 use the projected View command in the toolbar, and then select any of the standard views, drag it diagonally and you`ll obtain the ISO view.
    OSF.gif 147.8K
    Nicolas Ariza V.
    Use the projected view icon then click the existing view you wish to project from and project diagonally. That will create your isometric.
    @nav nice.
  • Jonathan_28Jonathan_28 Member Posts: 3
    Awesome. Thanks - a little different than what I am used to (solidworks) but that will work!
