Super Derive with images
graham_lock
Member Posts: 262 PRO
Hi,
I have a Part Studio which contains a master sketch image which I want to derive into a number of new Part Studios.
In each Part Studio I want to transform the derived master sketch such that I can align the origin appropriately for each part.
It seems that Super Derive does not derive images - is this the case or am I missing something - I'm new to Onshape so that's probably the case.
Thanks.
Thanks.
I'm hoping @ilya_baran can provide confirmation.
Your best bet might be to use the image FS: https://cad.onshape.com/documents/f7a45d78c374497d37c1d2cb/v/e55cc4b62eaac7ef75039ab2/e/557019cd8b843cc475681faf
I hope these Derive improvements also make Point Derive and Transform Pattern obsolete. There are many times that I want to derive parts, sketches, etc to a particular position in a part studio.
One thing I need to ask though is why are the imported mate connectors renamed with super derived and is there a quick change that can be made to the code to keep the orginal names? Just like the derive feature does.
Thanks
