Fill pattern: Pattern instances self-intersect
vladimir_shapranov
Member Posts: 9 ✭
I'm trying to use the "fill pattern" script and getting a confusing error:"Pattern instances self-intersect. Try a larger spacing."
From the code it looks like the error comes from a "catch the real error and rethrow some assumption instead" block, which is kinda bad.
try
applyPattern(context, id, patternDefinition, remainingTransform);
catch
throw regenError("Pattern instances self-intersect. Try a larger spacing.", ["distance"]);
catch
The actual error visible in the log is "PATTERN_FACE_FAILED", which is also not very helpful though.
How to fix this?
.0
If so, share your doc url please.
Oh, looks like I used some copypasted garbage version of the script (with different document id, but same name). Replaced with the one you mentioned and all works fine, thanks!
