John Steven Bowers
john_bowers023john_bowers023 Member Posts: 2
Fairly new to Onshape.  I am printing on a Creality K1 Max printer with a couple projects successfully completed.
I need to design a shift boot, which will seal a airplane nose wheel steering rod where it goes through the firewall.  The rod is a 10 mm diameter rod, and passes through a 14 mm X 60 mm vertical slot (because of the nose wheel up and down movement during takeoff and landing. I will use TPU filament because of its pliability.
What is an easy method to produce the flexing sides of the part??
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 953 PRO
    Draw a squigly line.
    Sweep it around an elipse or oval or something to make a surface.
    Thicken.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 773 ✭✭✭
    Shape? Round, square, other? - Scotty
    Thicken.
  • S1monS1mon Member Posts: 4,119 PRO
    In my experience, flexible 3D printed parts are really only durable enough for a short term proof of concept prototype. If this part is life-critical, I would question using 3D printing.
    Agree with Simon.  That said, if you've got the budget, this stuff is amazing:
    https://www.stratasys.com/en/materials/materials-catalog/fdm-materials/tpu-92a/
  • michael3424michael3424 Member Posts: 761 ✭✭✭✭
    I think that Formlab just released a silicone resin for their brand of 3D printers and that may work better than TPU.
