Why are Drawings only accessible to one user at a time?
StephenG
Member Posts: 367 ✭✭✭
Onshape makes a big deal about its ability to provide simultaneous editing access to its CAD data, as it should, because it makes concurrent collaborative design possible. To my knowledge no other MCAD product has this capability, (MCAD's answer to Google Docs.) however, this capability appears to only extend to Part Studios and Assemblies. Drawings appear to be accessible to only one person at a time, specifically, only one instance of a Drawing tab can be open at a time. Even when only one person is working a Drawing that person cannot create/open a duplicate browser tab of the Drawing tab.
This limitation makes it impossible to:
- See different sheets of the drawing at the same time. There are times when it is appropriate to simultaneous see different sheets of a drawing.
- Concurrently/collaboratively do design work at the Drawing level. It is not uncommon for different persons, with different roles and skills, to complete/finalize a design to the point where the product can be a manufactured. (Given the current state of Onshape, drawings are the bridge (necessary evil) between the 3D model and the manufactured product.) Only one person can work the drawing at a time. Even if the document has been shared View Only only one person can view the drawing at a time. Even the ability to follow the person who has the Drawing tab opened is not possible.
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381StephenG - We absolutely intend to support (first) concurrent viewers and then at a future data, concurrent editors.Philip Thomas - Onshape7
OptionsPeteYodis Moderator, Onshape Employees Posts: 524@StephenG As a current work around until we can offer concurrent viewers - you can duplicate the drawing tab in the workspace so that each person can view each drawing at the same time. Just delete the duplicated drawing tab when you are done, if needed.
You can also create a version and share that version. Versions can be viewed simultaneously.6
Comment: The inability to concurrently edit a drawing is a classic "Grid Lock" problem that Onshape is so keen to address, yet completing a drawing can be a choke point in getting a drawing ready for release because only one person can work the drawing at a time. This is especially a problem with multi-sheet drawings with a large number of sheets; it is not uncommon to have multiple "detailers" assigned to compete specific sheets to speed up the drawing process. For "file" based CAD systems that support multi-sheet drawings, where simultaneous multi-user editing is not possible, there is usually a technique that allows a multi-sheet drawing to broken into individual sheets, or groups of sheets, which allows multiple users to edit drawing fragments. Then there is a usually a technique to "merge" the fragments back into a single drawing entity/file. I know of no technique in OS that allows a multi-sheet drawing to be broken into unique drawing tabs: 1 sheet per drawing tab, along with ability to combine multiple single sheet drawing tabs into a single multi-sheet drawing tab.
You can view the drawing simultaneously on mobile
This makes its clear what is going on and gives the user 2 clear options. (Excellent wording in the Popup.)
Which begs the question: Why doesn't the browser based Onshape behave the same way? @pete_yodis, @philip_thomas care to answer?
We just moved to Onshape and are noticing that you still can't have multiple users viewing a single drawing tab.
Obviously you can't edit it from there but it solves the viewing problem.
