AI tool to enhance your renders: magnific.ai (maybe helps improve render studio results?)
I happened across https://magnific.ai in the newsletter "This Week in 3D" from Andrew Price (https://www.poliigon.com/thisweekin3d).
In short, it's an upscaling + detail adding tool that uses generative AI to improve images: hand drawn, photos, renders, etc...
Of course, I'm most interested in the render part, to see how can things I make be made to look more photorealistic (or just cooler.)
Here are some samples of inputs and outputs, prompt is at the end of this post.
Since they don't have a free trial, let me know if you have any images you'd like me to run through it. Post your render here, and I'll post back with the generated result.
I just ask that you limit them to no more than about 1000x1000 pixels, since the cost scales a lot with image size.
Onshape render of mecanum wheel:
AI output:
Render of underwater robot (done in Blender since Render Studio kept crashing):
AI output:
The prompt/setup (same for both images):
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
1
Here is one you can try. It's pretty good except the food is a little under-cooked and plasticky. Table is too clean as well.
size 1000 x 563
Here it is "optimized for" set to "3d render":
@Ste_Wilson it's pretty subtle! Here is a close up of one area:
@Rhett_Robinson yes - it has the following modes:
@MichaelPascoe here it is! "standard" optimization mode:
"3d render" optimization mode:
@_anton, Yeah, its a cube that I slapped a material onto XD.
https://www.vizcom.ai/
With limited sketches and text you get an ai rendering. It's not going to replace the real thing all the time, but it is useful enough to get a lot of buzz and funding.
