Helix sheet metal
santossgsantossg Member Posts: 2
I have this part. How can I have a sheet metal from this? Some one can help me please?
  • robert_johnstonrobert_johnston Member Posts: 62 PRO
    I'm just bumping this thread,
    Interested in the onshape sheetmetal experts if you have a way to do this or future capability? This is a little alongside the sheet metal loft capabilities we need.
    I use bricscad to get these flat outside of onshape. The more bends you do the smoother the helix is.
    Regards fabricating them, with a press bends have to be straight, otherwise spcial tool/dies can pull twist these. There is likely a more expert screw fabricator on here than me!
    The new bend fature in onshape actually allows us to import flat dxf, thicken and bend on the line now.
