Sweep 1 Rail
I think I'd say my biggest issue/bone of contention with OnShape is the Sweep tool, and how sometimes I have to think about 'Lofts' where I'd traditionally think of needing sweeps. My background is with Rhino, so accept my apologies for expecting something to behave like something else.
See below - there are 3 straight cross-sections  and two segments for a rail. There are so many cases when I might only need even one of these rails, for example creating a swept surface along a rail using two existing surface edges. The issue with loft in these situations (using the long edge as a guide) is that you won't get the nice interpolated second rail that I would expect. For a guide, check out Rhino's (by most accounts) 'vintage' Sweep1 tool, and just picking a rail and two sections. OnShape's behaviour which creates multiple Sweeps for each section I pick to sweep along absolutely baffles me (although I appreciate what it thinks I'm asking for).
@GregBrown - is this maybe your ballpark?
  • S1monS1mon Member Posts: 3,778 PRO
    Can you share a public document?
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 368 image
    Will be happy to take a look...
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 145 PRO
    Hey @S1mon, yeah I'll draw up an isolated example! Thanks both. In the end I had to give up on trying this particular workflow, but the ruled surface (which contains some Sweep 1 rail-ish aspects) helped me over the line for now.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 121 PRO
    Did you get around to getting this resolved? I've run into a few instances where having a separate guide rail in my sweep would've been very helpful.
    Ramon Yip | glassboard.com
