Extruding a text form to hold a LED strip.
Hi all,
I've been following training on onshape and am impressed with what is possible.
Now I've been foolish enough to promise a friend of mine to make a "neon" sign with her daughter's name, using a LED-strip so it can change colour and we can have the colours running, etc.
I've tried a couple of methods but nothing seems to work.
Importing the text (in a special font) as SVG, then using splines to "copy" and mold the shape in a new sketch, and I thought extruding that would work. But, it seems the constraints don't hold. Not sure why. Also trying to use the offset tool creates all kinds of issues, from parts of the splines disappearing to the offset not being respected after I further work on the sketch.
I've also tried using a shape-and-sweep approach but given that the letter cut into themselves, this also cause again issues.
It's probably me missing somewhere a vital insight into how I am supposed to do this but I'm at a loss at this moment.
If someone could enlighten me on how I am supposed to do something like that, I would really appreciate the help.
The project can be found here. You will find the A already extrude but the offset has gone all over the place.
https://cad.onshape.com/documents/0a6022cb0fc092b790f6b26c/w/0839b7c8d7ccf8b92e9f7b4c/e/006bf55074b7591ccbff041d
Thanks in advance
Hey Bart... I thought about this for a bit and tried this "other" approach. The fundamental difference here is the use of Extrude Thin (which also allows for the use of a single spline line to define the letters)
This approach does allow easier adjustment of the width of the letters (to a point) by using a variable to drive the dimension of the Extrude. I say "to a point" because if the width exceeds a certain dimension you will run into intersecting geometry, which is not allowed (this can be solved by enlarging the geometry of the sketch where that intersecting geometry is occurring). Also, the need for multiple "Extrudes" is driven by intersection geometry constraints as well.
I know you said you basically "had this solved"...so just throwing this out there as another approach.
