Im having a translating fail from importing a e-plan library component is there any way to fix it?
remon_overwegremon_overweg Member Posts: 2
I used a X_T file format to try and load the 3D component into onshape
  • S1monS1mon Member Posts: 3,745 PRO
    X_T is a text based version of Parasolid. If you have an option to get X_B, try that. I've seen situations where text based files can be corrupt moving from one operating system to another (MacOS, Windows and Unix all have different terminator characters for lines of text).
