How do I use extrusion to remove a shape from a surface when using parts in an assembly?
hedley_phillips
Member Posts: 11 ✭
in General
First a link: https://cad.onshape.com/documents/35b1b610b6032665bfff9301/w/3828f7fba2459f69ba8cf07d/e/7d7662a159dfd3c27c0514e2?renderMode=0&uiState=6611413729596d5036d48cae
I'm using assemblies for the first time and was feeling all clever. But it's gone wrong.
I want to create a shelled out box (part 1) and then an extruded shape (part 2) that is mated to the base of the box and removes that shape from the base of the box. So in effect create a Letterpress style effect. I managed this when I had my box and the shape all in one part but was wanting to try assemblies. The issue I have is that the shape I want to remove from the box can't be a remove extrude in its own part as there is no material to remove from and it goes red and fails. So I have to use an add extrude which isn't then removing that material from my assembly.
Does this make sense or have I completely confused everyone? I want a box with a design negatively exctruded in the base.
Can anyone point me in the right direction?
Thanks.
Thanks.
https://cad.onshape.com/documents/876cd7da860d4c14b3b81810/w/8c4e8033cb786c26786d4e0c/e/87ae9d41e9e5295be8c3f2c2
https://learn.onshape.com/learn/course/managed-in-context-design/introduction-to-managed-in-context-workflows/what-is-managed-in-context-design
I then tried again and it hasn't disappeared but it's failed to resolve instance. Will go back to the docs and read some more.
https://cad.onshape.com/documents/876cd7da860d4c14b3b81810/w/8c4e8033cb786c26786d4e0c/e/6c3c547d91bf14b373248efc
To simplify, see combined part studio. No need for in context edit when making multiple parts in one studio.
The learning center is a great place to start if you're new to OS and it's free.
https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22All%22%5D
