need help with merging 2 parts
nelson_pereira280
Member Posts: 37 ✭
Hi all,
I am making a smart phone charger magsafe holder. Initialy, i did a holder with only 1 magsafe charger. In the document below, you will see a second one that has a flat section for another magsafe charger. My issue is I wasnt able to merge the 2 base together for some reason, every time i try to delete the line between the 2 sketch, it screws up the whole design and I dont know how to fix this apart from starting back from scratch.
Can anyone help me in telling me how to bege the 2 base plate in sketch 1 ? Thanks
https://cad.onshape.com/documents/0fe77cf87dae0b5520d0efbb/w/8d06a38538f8e94a8d9b7626/e/651cb6ca8bdccc8171b68817?renderMode=0&uiState=661416de231c8b78ed29d83f
_anton
Member, Onshape Employees Posts: 505
The conflict structure is a bit difficult to diagnose. I think the immediate issue is that that 80 constraint at the top of the sketch is actually 80.00003 mm. In combination with the other constraints, that skews the whole right half of the sketch.
In addition, there seems to be some numerical oddness b/c, if you constrain that horizontal construction line to actually horizontal, the sketch breaks. Which isn't what I'd expect.
Some pointers on sketch construction. Try to avoid coincident lines b/c it's hard to pick one vs the other. If you need a two-part rectangle here, just reuse the original rectangle and draw a line down the middle, or draw the remaining three lines manually. I prefer to explicitly specify coincident and horizontal/vertical constraints, which tends to prevent non-obvious misalignments like this.0
Fixed: https://cad.onshape.com/documents/3e1ac1bcbb53a6e3a189a42c/w/e351e201bff0fd0d658bfdb6/e/a9d72455b21821b6bed1d17a
i tried to make the 2 lines coincident but the whole sketch becomes red.
