Copy Read Only no longer available
Garrett_RichardGarrett_Richard Member Posts: 2 PRO
The option to copy read only documents has been removed according to a few YouTube videos. I could not find any work around for this and am unable to get a copy of exercise files such as universal joint to complete exercises in the assemblies course.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,936 image
    If you are using Onshape Enterprise, it is likely that your admin has disabled the ability to create documents in the root folder. You can tell if this is the case, as the document option under the create menu will be greyed out. You will have to ask your admin to copy the docs for you.
