Hope to add a windows font to a face of a dial
brian_sweet
Member Posts: 12 ✭
Hello to this kind community. I am trying to figure out a way to add numbers (0-9) to a circular face for a counter. I would like to use a font I have, but could settle with a font in OnShape if I needed too. Here is a mock-up of what I am trying to achieve in the end. I would like to have the numbers on a sketch to extrude off the face. I am just not sure if what suggestion you may all have to do this.
I have though of making the numbers as an DFX and adding them to the face. But would rather try and do it in the sketch.
Here is my test:
https://cad.onshape.com/documents/702442b1fcc66791f7b9d4c0/w/b7ca4e03792b337f440521c6/e/1f0dd75ae0b90afc38689a29
Here is my test:
AFAIK, though, it can only support Onshape fonts.
I made a copy of your doc and used the feature to get you started:
https://cad.onshape.com/documents/4bfa67763847c6e83a3095ae/w/17469290441cf292a53e2cd7/e/acdc601f250993b096330e77
You can read how to use it here: https://forum.onshape.com/discussion/23648/new-feature-text-path
