How do I convert from surface to a part?
Hello,
https://cad.onshape.com/documents/5cab9c8bd0c06800a23058dd/w/21f41b44ed254d01afa55610/e/7c29c9f531cc0f9dfe76bf91?renderMode=0&uiState=661944bfbb351732e9895119
I am having trouble with this CAD model of an aircraft where I want to make it a part instead of a surface. As you can see, the object is already filled at the wings but Onshape sees it as a surface. I tried using the enclose and Thicken but nothing worked as there are errors.
Thank you.
  • GWS50GWS50 Member Posts: 455 PRO
    edited April 2024 Answer ✓
    Here is the model as a part.
    There was an 'open' section that was preventing the surface becoming a part.
    https://cad.onshape.com/documents/3ea65f25053bd9d55bef6189/w/b1a36d33a30fc385c9ad95fd/e/c067ff590abb44c4de9af93f
    A helpful way to locate these open areas is to extrude a surface and use it to perform a split in the imported surface and then use the enclose command to see if one side of the split will then become a solid part. By moving the splitting surface to different locations you can then isolate the offending area. (See Part Studio 2 TAB)
    I hope this makes sense
  • S1monS1mon Member Posts: 3,415 PRO
    You'll need to make your document public in order for us to help.
  • abdulla_hadramiabdulla_hadrami Member Posts: 5
    I made it public
    Thank you so much!
  • martin_kopplowmartin_kopplow Member Posts: 837 PRO
    There should be a diagnosis-tool to find open faces or bad surface joints in OS. That has been an industry standard for years im many CAD systems.
    you can use 'Highlight Boundary Edges' but it's not always that clearly shown with a complicated open surface, (can be hard to spot)
