Boolean subtraction not working due to geometry
brett_jones039brett_jones039 Member Posts: 4
edited April 2024 in Community Support
Hi there, I have a drawing that I'm trying to complete. Unfortunately, due to my lack of skill, I can't seem to get this to work. I know it is messy, but I'm so close! Just the last boolean is left. I wonder if anyone can help me get this to work.
Screenshot (couldn't get it to upload directly): https://drive.google.com/file/d/14Ot9FvcuLpCb2-RuxoMGYxB4JNIGli0r/view?usp=sharing
Link to drawing: https://cad.onshape.com/documents/e3f4fd9e920b1e569bc6d4b0/w/bdbc5a5e03c082ba6c435978/e/c36bc2c48633bcc3af229ccf?renderMode=0&uiState=661b7ffd79b42b4f5d88ea4b
Thank you in advance for any advice/solutions!
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 948 PRO
    edited April 2024
    Why are you using those dxf imports for the text? Use the built-in text tool instead. Several fonts are available, and the modeling will be 10 times easier.
    CAD Link:
    https://cad.onshape.com/documents/ae2ed78acd67ba8e2ccec134/v/3d66e90c4c996e885b9a8f1a/e/fa31f8e4cf017140c93b8ceb?renderMode=0&uiState=661be4610a26f573f1444624
    edited April 2024
    I checked your model, the root issue is the height of the 0 number is not high enough. Do a move face on it to make it taller, then the union will work.
    That said, I'm not sure what you are trying to do. The model is super super super complicated. dxf imports of text that is very jagged. Transforms all over the place. Extruding the same surfaces over and over. I'd start over completely and do it the way I did, using the built in text tool. There is no need for the transforms or the other stuff you have in your model.
  • brett_jones039brett_jones039 Member Posts: 4
    Hi Nick,
    Thanks for your replies. I have some plasma cut numbers that I am trying to insert into this part tightly, so I need the DXF imports (they are scans of the real-world pieces with all of their imperfections). I then needed to make the cutting tools slightly larger to add tolerance, so that's why there are all the extrude and thicken features (messy, I know).
    I don't know what "a move face" is, but I will research it and hopefully figure it out!
