Letter Stamp for Concrete Curbs
This is what I'm trying to model.
A simple stamp for work that I can 3D print.
We now need one for irrigation that says "IR" (backwards, because it's a stamp)
I found it easy to create text then extrude it, but I kind of need that wedge shape.  (example is not backwards, I know)
I then tried to make letters from scratch .01" wide and then chamfer them, but it was painfully unsuccessful.
I need a different approach.
Here's my working file to share if it helps:
https://cad.onshape.com/documents/123f489493fcba9f8e7b6d01/w/55c38f8df19aa551a6aba6e7/e/2908507f0ad0ff60247c8836?renderMode=0&uiState=661ddac7d99169347c97bb57
Thanks,
Kevin
Trying to make:
first try:
2nd try, tedious:
  • GWS50GWS50 Member Posts: 500 PRO
    edited April 2024 Answer ✓
    Here is one way to do it.
    You can flip the text in the test dialogue box, vertically or horizontally. I then used the draft tool. You may need to do the draft in a couple of stages to get more control over the different letters
    https://cad.onshape.com/documents/813429ae820c8c966ba699c0/w/d301d728ddea2ab60bfeaf0f/e/dfda4656e9e3572a47101efb
  • rick_randallrick_randall Member Posts: 416 ✭✭✭
    If you want sharp corners at the apex of letters, I found it easier to just model the text with single lines and triangular profile sweeps. The lines of the default text are not parallel and/or evenly spaced and if you draft text to much the letters start looking wonky - otherwise, GWS50's example doesn't look all that bad.
  • kevin_mcdowellkevin_mcdowell Member Posts: 5
    Awesome.  Thank you.  I think Draft is going to work well.  I just need to find a font that has consistent line width.
    I'm going to try to do a triangle profile sweep as well.  Both great ideas.
    I think I tried Draft originally, I just didn't know how to use it correctly.  Your example not only showed me an idea, but showed me how to use the tool as well.
    Thank you.  Exactly the help I was looking for.
