Is there a way to create a customize mate?
Ulises_FM
Member Posts: 74 PRO
In OnShape, mates are defined so that they resemble mechanical connections. However, they are limited to specific kinematic combinations (for each mate, certain DOFs are restricted).
I'm trying to use OnShape to model a specific kinematic behaviour that does not correspond to any of the existing mates. (eg. Rx, Ry, Rz, Z are free | X, Y are restricted)
Is there a way to define something like a customized mate for which you can specify which degrees of freedom are restricted and which ones are free?
Thanks!
Thanks!
Or using an intermediate "dummy part" and two separate mates: for example a sketch surface as a slider and a ball mate to that surface would provide what you are looking for (I think?)
What I did was exactly that, I created three different parts, each one of them with an associated mate connector. Then I used a slider mate fom the first to the second MC, and a ball mate from the second to the third MC. Is there a way to simplify this process?
You could use the "fake mate connector" FS to create your "dummy" intermediate part a little bit faster: https://cad.onshape.com/documents/c17cc15051561f01e2fc6d0d/v/13b76dd8f102481f2f21857a/e/81e13b859e7facbfb47d1355
https://forum.onshape.com/discussion/23797/universal-custom-mates/p1?new=1
