How Do I Reach Out to FeatureScript Dev?
ben_kraftben_kraft Member Posts: 5 EDU
I am attempting to bug report for FeatureScript's Point Pattern but am not sure how to reach out to any devs since I cannot find anything online or on featurescript docs. Any help would be appreciated!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    It was never intended to do that - it is only taking the origin of each MC as the point to pattern.
    What's the bug?
  • ben_kraftben_kraft Member Posts: 5 EDU
    I'm attempting to use Point Pattern on a feature across multiple faces of a part using mate connectors for the reference point and target locations. I expected that selecting Apply per instance would orient the patterned feature in the new axis of the "Location" mate connectors, but it only applied it in the original axis.
    Makes sense, I've found that Transform Pattern fills the need I was looking for!
