lofting from a sketch gets screwed up by other sketches on the same plane
this feels like a bug because the Loft menu box says "Face of Sketch 1" but it's showing a bunch of shapes that are distinctly *not* in "Sketch 1"
to avoid lots of zooming and clicking, do i have to put all these sketches on their own planes?
He's saying he only selected sketch1 which doesn't have any internal regions. But the red preview does suggest there is a face of the solid selected in there somehow.
You also only have one selection for the loft, did you try picking another profile for the loft to see if it solves it? It could just be a graphical glitch (refreshing should also clear that if that's the case).
We might be able to figure what's going on if you share a link to your doc...
when you create a "New sketch" from the surface of a Part, this new sketch becomes cursed forever by the ghost of the Part's perimeter in that plane
i'm worried that this is a Feature since i could imagine it could be useful at times if someone is aware of the behavior, but it's caused headaches for me before, and seems distinctly bad. since i feel like you should be able to see that something is a Sketch, and understand everything about the Sketch from the Sketch itself. without needing to remember hidden artifacts lingering around as side effects from the specific way that Sketch happened to be created.
for example, here i have two sketches. Sketch 1 is clearly a circle, and Sketch 2 is clearly a rectangle
now i'd like to loft my rectangle:
but i cant. because there's an undead circle hiding inside it that i cant get rid of,
because of how the rectangle was created. (by creating a "New sketch" from the other end of an extrusion of the circle sketch)
https://cad.onshape.com/documents/a82f03eed8bf29ae67e2de8e/w/2e833e275c987e44d42fc3d0/e/d854c39f0f00246eaa8f19d4
https://forum.onshape.com/discussion/comment/101644#Comment_101644
