How to import vector graphics from a PDF?
martin_kopplowmartin_kopplow Member Posts: 987 PRO
I have a PDF file that holds a shape in vector graphics (2D Bezier, I suppose) and nothing else. I was told it had consistent tangency and so on, and I want to use this shape for a design (say a Logo that has to be built in 3D) and NOT convert it to DXF before that, since DXF appears to always come with a considerable loss in spline quality. Also' I'd like to keep a door open for replacing the whole shape in the sketch later, should there be changes coming from the CI team. Ideally, I'd import the PDF directly into a sketch and then build upon that, but that's seemingly not possible.
What do you think would be the best practise to get this done in an elegant manner?
  • S1monS1mon Member Posts: 3,618 PRO
    Adobe Illustrator or Inkscape can convert vectors to DXF that will import into Onshape without losing quality.
  • martin_kopplowmartin_kopplow Member Posts: 987 PRO
    Inkscape was the first method I tried. The DXF came in as a collection of short lines, as opposed to the splines I saw in Inkscape prior to export. Were there supposed to be real splines in the DXF? If so, something must have gone wrong. I'll have another go on it.
    @S1mon It works now, via SVG-File->Inkscape->DXF14. Most of the tangencies are preserved, I had to heal just a few. Onshape can obviously load and display SVG images in a tab. Unfortunately, it seemingly can't actually import them as geometry, wich is a pity. If it could, that would make the workflow with graphic designers much easier, and since OS can already export drawings as SVG, this would then offer a 2-way exchange path.
