Multiple Fillets
GWS50GWS50 Member Posts: 498 PRO
Is there a way to put multiple fillets in a sketch that are all equal to each other?
Presently I insert several fillets on a sketch, then delete all but one of the dimensions and then make all the fillets equal to the one with the dimension still attached. I can then alter all the fillets by altering the one remaining dimension. This is a bit of a fiddle....is there a better way?
