API | PartStudio | Mass Properties
Martyn_Gierlicki
Member, csevp Posts: 3 PRO
Hi all -
I am using the Glassworks API Explorer to pull the mass properties from a part studio (https://cad.onshape.com/glassworks/explorer/#/PartStudio/getPartStudioMassProperties).
I am pulling the data into Excel Power Query via the generated Request URL from the glasswork API tool.
Now - my part studio contains muliple configurations which contain various quantities of parts. I know I can hard call a specific configuration into the URL to GET the details of that specific part studio configuration but is it possible to generate a single request URL for all of the configuartions within a part studio.
I have in the region of 80 configurations so dont particularly want to have to create 80 URL's and 80 power queries.
Thanks in advance.
Thanks in advance.
You can use the endpoint:
/elements/.../configuration
to get a list all of the parameters of a configuration, and then use the allowed values to generate a list of all of the configurations.
For inputs like length, these are obviously infinitely variable, so you will need to determine a method of iterating across that value, or leaving it as a default.
Good question! From what I see, the API call only lets you pass a single configuration at a time. Is there any way to request all configurations in bulk for a Part Studio, or would this have to be handled by looping through the config list outside the API?
