Extrude Up To Face
price_cobb
Member Posts: 38 ✭
in General
Folks, I've recently drawn up a part that needs to be flipped on a bench once made (FDM printed in this case) and held relatively securely so why not make a perfect part for this to rest in from the drawing itself?
Having used Extrude To Face with success before, and ironically even this part has this done underneath, I'm a bit lost as to why OnShape won't do this now.
Red box is simple a rectangle drawn on a plane. Something made and extruded often. The UpToFace is the Face Of Thicken 2 which is the area being touched by the arrow.
Happy to share the file. Otherwise, any ideas are very appreciated.
https://cad.onshape.com/documents/822619ed754f4a8b736abe84/w/78899c6ba2e18c191eeb7e4b/e/9c48050efb5b7ed3808cf11f?renderMode=0&uiState=662e558ed7c36c556b0dcc70
As a reminder I'm wanting to "loft" the orange bar up to the multi curved surface of the blue part just beneath it. This will be it's own part as it is my intent is to create a tool, or support if you will, to lay the printed blue part into on my bench to then work on the blue part's underside which is the side that has all the stuff going on. Hope that makes sense?
The thick irony, to me anyway, is that if you flip the blue part over, you can see that I lofted the lugs (where each of the four holes reside) to the inside of the very same surface I want to loft the orange bar to! I've no doubt that all my goofy geometry (the way I created the part in the first place) has something to do with why OnShape isn't interested.
Feel free (of course) to either make the changes to this here OR, to make a duplicate and work from there. Both work for me so no worries.
Any help at all and I'm indebted.
TYVM
