Stuck on Loft tool use
alex_giuliani
Member Posts: 4 ✭
in Drawings
https://cad.onshape.com/documents/e9b081d988abf5d0e12f7f20/w/e8e019799cc004b46ea168b8/e/324e54bcf34f2d9bd0c5205a?renderMode=0&uiState=6629d0f9e2ec4b7fda863562
https://cad.onshape.com/help/Content/loft.htm?Highlight=Loft
Hey Alex, good job figuring things out...I took a look at your doc and it seems like you have the Lofts figured out. As is almost always the case with OnShape there are many way to get the end result you need. In the end that is really all that matters....so two thumb-up for you!
So for a bit of feedback, you have a LOT of stuff going in your model (59 Features)...there are a many extra steps that could be eliminated with a different approach and some forethought about the overall workflow of your design (and perhaps some techniques you haven't yet learned).
I modeled this with just 18 Features. If you'd like to take a look at this approach hear is a link to my doc.
https://cad.onshape.com/documents/f8910bd718017fcf6040775a/w/b060c7d5093c677fd4d210fb/e/801428ecf1253f12a14224c2
OR perhaps, the top faces of the Lofts is not quite what you want...in that case, check out option #2 (Opt2 tab) in the doc.
