How can I fill out the fields in the drawing templates?
hansrudolfhansrudolf Member Posts: 55 ✭✭
I'm sure the answer is out somewhere, but I didn't find it...
When I print out a drawing the template shows 'Title'. 'Drawn', Dwg.No', 'Date' etc.
How can I insert meaningful data into these fields?
If this is only possible by creating a custom template (and a new one would be needed for every drawing, then I would like to know if the custom template(s) count as private documents?
Regards, Hansrudolf
  • hansrudolfhansrudolf Member Posts: 55 ✭✭
    Many thanks Gonzalo and da_vicky, I did manage to put text into the template form. Good to now that I could make a public template; at the moment I see no necessity.
    Kind regards, Hansrudolf
