Create a drawing of the face of an object
mitch_b708
Member Posts: 17 ✭✭
I have modeled two parts that are inclined about 10 deg (they are mirror images of each other). I intend to cut each out from wood (e.g a 1x12) and connect the two parts with a hinge.
So, I am trying to create a drawing of the face of the part, so I can print it and use it as a template to cut the shape from the wood board.
The problem is that the part is added to the drawing at an angle which doesn't give me the correct shape.
How can I create a view of the part that is normal to the face?
One workaround is to create a section lengthwise through the object, but that seems indirect. I'm new to OnShape, so Im hoping to learn a little bit more with this question.
Thanks,
Mitch
Thanks,
Mitch
MichaelPascoe
Member Posts: 2,681 PRO
Hi @mitch_b708
Here's a solution that may work for you. While inside a drawing sheet:- Right click the drawing view
- Align view
- Vertical
- Create a new Auxiliary view
- Hide the unwanted edges
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
