How to use Move boundary in FeatureScript - opMoveBoundary()
MichaelPascoe
Member Posts: 2,814 PRO
I was having trouble finding how to use the Move boundary within FeatureScript. There is no OpMoveBoundary or OpExtend like you would expect. Here is how you can do it:
Import the extend FS from Onshapes STD at the start of your project.
Next, define the definition for the extend surface and call the function:
// For move boundary import(path : "12312312345abcabcabcdeff/6509fdce3abecacec8f38b8a/cffdc47ca3931d4c4d41ee51", version : "0e66a19d0a986e71c5d22df8");
// Extend ends using move boundary
const extendSurfaceDefinitionLeft = {
"entities" : leftEnd, // Query
"tangentPropagation" : false, // Boolean
"endCondition" : ExtendBoundingType.BLIND, // ExtendBoundingType
"extendDistance" : definition.extensionLeft, // Length
"oppositeDirection" : false, // Boolean
"targetPart" : qNothing(), // Query
"targetFace" : qNothing(), // Query
"targetVertex" : qNothing(), // Query
"maintainCurvature" : false // Boolean
extendSurface(context, id + "leftEndExtend", extendSurfaceDefinitionLeft);RENDERCAD
3
RENDERCAD
And of-coarse if you're trimming edges back you'll need to use "opEdgeChange" you'll have to figure out how to use it by studying the "Extend" tab in std library source: https://cad.onshape.com/documents/02e253006c3b752eb13303a7/w/7b120b69b752b11fdbbb09dc/e/4b13fb3967e27f942c8ae475
Actually I'll go one better: I've made an opTrimEdges function in case anyone wants to trim back the boundaries of a sheet/surface:
export function opTrimEdges(context is Context, id is Id, surfacesOrEdges is Query, trimDistance is ValueWithUnits, tangentPropegation is boolean) { //get edges and track them var selectedEdges = qEntityFilter(surfacesOrEdges, EntityType.EDGE); if (tangentPropegation) { selectedEdges = qUnion([selectedEdges, qTangentConnectedEdges(selectedEdges)]); } var allEdges = qEdgeTopologyFilter(qUnion([selectedEdges, qOwnedByBody(surfacesOrEdges, EntityType.EDGE)]), EdgeTopology.ONE_SIDED); var trackedEdges = []; for (var edge in evaluateQuery(context, allEdges)) { trackedEdges = append(trackedEdges, qUnion([edge, startTracking(context, edge)])); } //Make array to use in edge trimming var edgeChangeOptions = []; for (var i = 0; i < size(trackedEdges); i += 1) { var edge = trackedEdges[i]; edgeChangeOptions = append(edgeChangeOptions, { "edge" : edge, "face" : qAdjacent(edge, AdjacencyType.EDGE, EntityType.FACE), "offset" : trimDistance}); } if (edgeChangeOptions == []) { throw regenError(ErrorStringEnum.EXTEND_SHEET_BODY_NO_BODY, ["entities"]); } //trim edges try silent { opEdgeChange(context, id + "edgeTrim", { "edgeChangeOptions" : edgeChangeOptions }); } catch { var edgesToTrim = []; for (var i = 0; i < size(edgeChangeOptions); i += 1) { edgesToTrim = append(edgesToTrim, edgeChangeOptions[i].edge); } setErrorEntities(context, id, { "entities" : qUnion(edgesToTrim) }); throw regenError(ErrorStringEnum.TRIM_FAILED); }}
Two more things to note that I've learnt is:
