Simulation
GWS50
Member Posts: 498 PRO
in Simulation
I have a Box Section Frame made with the Frame Tool which generates a composite part when a cut list is created.
My question is - Simulation wont run on a composite part so do I have to create the assembly with Fasten/Fixed Mates in order to run the simulation or is there a work around?
Seems like a lot of extra work to create the assembly rather that just using the Composite Part.
wayne_sauder
Member, csevp Posts: 639 PRO
@GWS50
I have discovered the same thing, along with this is the fact that with assembly the calculation time can get very long.
For frames, I often try to create them in such a way that I can boolean all parts into one at the very end then after I'm done with the simulation I delete the boolean.
Submit a improvement, I'll vote it up.1 -
S1mon
Member Posts: 3,949 PRO
With the simulation tools, Onshape sells the idea that you can just do everything in the main assembly of the same document. While technically true, I find that it’s often better to have at least a separate part studio and assembly where you derive the things you need and do whatever special fixtures or in this instance Boolean addition in there. You can go a step further and make a separate document. Real world assemblies are often way more complex than what you need to simulate and don’t have the needed ground parts to constrain things.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1
thank you both for your guidance
Configurations are OK as long as you don't have too many parts to configure, a separate part studio does make things nice and separate though
Thanks for the tip in the help,
Tremayne Eichmann Geometry Vibes
