One method to wrap a pattern around a irregular shaped object
eldon_browneldon_brown Member Posts: 50 ✭✭
I think I found a way to wrap a pattern around an irregular object, in my case a "vase".
First create the pattern, wrap it around a temporary larger cylinder and include the vase as part of the Merge Scope, delete the pattern and cylinder.
Some fiddling of the pattern size is necessary to join the pattern on the back side.
I hope someone finds this useful.
If there is a better method, please provide.
--Eldonb
