One method to wrap a pattern around a irregular shaped object
in General
I think I found a way to wrap a pattern around an irregular object, in my case a "vase".
First create the pattern, wrap it around a temporary larger cylinder and include the vase as part of the Merge Scope, delete the pattern and cylinder.
Some fiddling of the pattern size is necessary to join the pattern on the back side.
I hope someone finds this useful.
If there is a better method, please provide.
--Eldonb
--Eldonb
https://cad.onshape.com/documents/66a3da002a0d5b980dc8e723/w/b8be0d1038fa2f8a6fd1a61f/e/2dda3ff9be4c37922e5d090f?renderMode=0&tangentEdgeStyle=1&uiState=663c9b54096e4613f47857bc
I love this Forum, . . . where good ideas come together.
Thanks for sharing.
--Eldonb
That's nice. Perhaps you would prefer to use the 'Remove" option of Circular Pattern, rather than creating and selecting many objects and applying a Boolean Subtract.
