A dimension cannot be created between these points
gary_green818gary_green818 Member Posts: 7
Onshape for iPad
1.  Started sketch
2. Created rectangle on front plane, froze plane so it doesn’t jump around
3. Selected front plane
4. Selected Dimension tool
5. Tapped screen to show cursor
6. Dragged cursor to highlight corner point, lifted finger and point stayed highlighted
7. Tapped screen to show cursor
8. Dragged cursor to highlight another corner point
9. Point does not highlight when I lift finger
10.  Message displayed, “A dimension cannot be created between these points”
What gives?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,868
    Don't do step 3.
  • gary_green818gary_green818 Member Posts: 7
    Same thing,  “A dimension cannot be created between these points”
    Think we’re getting closer.  When I create a new sketch, it works.  Somehow additional sketches get created.  I don’t create them overtly but the system does it.  After that happens, the error message pops up.  Is there some constraint that prevents dimensioning with multiple sketches?
  • joshtargojoshtargo Member Posts: 334 EDU
    the system does not create sketches on its own.  can you share and link to your document?  make sure public can view
