Specify configuration on Partstudio translation - API
marcus_schaefer
Member Posts: 7 PRO
I am trying to convert a specific configuration of my partstudio to a step file and I keep getting the default configuration. I'm assuming that this configuration string is where to specify and I have tried "configuration={config_parameterID}%3D{config_parameterValue}" (the normal configuration string format), but it still gives the default configuration. When I try it without the "configuration=" just "{config_parameterID}%3D{config_parameterValue}" I get an error. It seems like the first format is accepted but doesn't give the correct result. Has anyone had any success with this or have any ideas?
But when it's in the body of the request you also shouldn't URL encode it, which I can see you are doing by the inclusion of %3D. URL encoding is only needed when it's a URL parameter.
