Creating a Cutlist with Dimension in Onshape
Hello folks,
I'm a complete newbie to Onshape. In principle I'm getting along well, but I'm just stuck on one point: I want to create a parts cutting list with the appropriate dimensions so that I can saw the parts out of the panels.
I created a cutlist with the respective parts in Onshape and it also appears in the right panel. However, I don't see any dimensions. I'm sure it's just a small thing. I've read a lot in the forum and online, but couldn't find a solution.
I have attached a screenshot of my view.
I really look forward to helpful comments. Thank you very much!
Best regards, Andreas
Here you can find the project I am working on:
https://cad.onshape.com/documents/5511c93705114649c2287182/w/a24df4a189cf3098211f734c/e/6a666a314115d9d0fd190cd5?configuration=List_dzOZTtD0brbrEZ%3DStandard&renderMode=0&uiState=658fde2b213a1834573bd792
https://cad.onshape.com/documents/f78dd4fe3bc815b0618f9819/w/3dcfc5806906a3621f9a2d48/e/92c4751e4b9df9722bca5035
thank U very much for your reply. But I just want my parts to be listed with dimensions in the cultist. I don't need frames.
Regards, Andreas
damn i was hoping to find the answer here… im also stuck with the same issue.. i just need measurements of the parts i just created. its really simple.. is it a feature just in Pro version?
@quentin_sandberger no you don't need the pro account. The free account has access to all of the part studio features.
If you don't want to use the frame feature, you can try the Measure Cut List feature.
Also, if your parts are more complex you could always place them into a drawing and put dimensions on it.
