Editing Constraints on iOS
Bluchip
Member Posts: 20 ✭✭
Pretty much what the subject line refers to…
How do you edit a constraint while sketching using iOS?
I have an iPad Pro and I have a tangent constraint I wish to delete. Onshape help state you can edit constraints in iOS. But I haven’t been successful at it. Understand how with browser version and PC. But the mobile version has fooled me!
I have included a screen grab that shows I have the desired tangent highlighted but cannot seem to figure how to delete it.
Thanks!
Select constraint... Swipe Left!
john_lopez363 that’s the ticket. I tried selecting, two finger tap, etc etc. That’s a little different from other deleting processes but that will do! Should have tried that as it is so common with other IOS operations.
Thank you so much!
