Only on some models : Onshape is not connected. Your document is saved. Refresh the browser to cont
RichPenn
Member Posts: 4 ✭
My user name is : richard_haynes953
The document in question is : Teaching Tech Parts Examples (Tab name is "drill shelf")
My computer is Win 10 on Asus mobo AMD3700 w/ 16Gb ram and Nvidia GeForce RTX 2070 Super - latest drivers and mobo BIOS updates. Problem exists with Fire Fox and Chrome on some models only ...
Most documents work find but I have a couple that will not open, I get LOADING STUDIO and LOADING DATA then the disconnect message.
I have tested by disabling the ethernet port and using WiFi connection but no change was noted so I don't think it is the network drivers .....
NOTES:
I am able to open these same models with 2 other Win 10 computers without issue.
Both of these computers are small laptops.
They are on the same network and the same router.
They can open the model using either Cat5 or WiFi so I don't think this is a network socket issue.
I am at a loss trying to discover why this one machine fails to load the model when others will. This happens with Fire Fox and Chrome.
I have flushed all cache for both Fire Fox and Chrome and rebooted the computer
but I am still getting the Disconnect part way thru loading the model shown above on this one machine.
Is there an error log I can look at or is there a way to turn on error logging in hopes of finding what Onshape code is not finding?
Thank you for your help and for a really great tool !!
Richard
NOTES:
Richard
Richard - CAD/CAM systems engineering (Retired)
2
NeilCooke
Moderator, Onshape Employees Posts: 6,022
You can also open the developer console in the browser to see if any error messages appear.Senior Director, Technical Services, EMEA0
I don't have this problem on another PC in the same networkI think the check is ok
I get this error only on some documents and not on another pc in the same network ?
I was drawing and by confirming sketch I get this error. I can open all other drawings, but not this one. it seemed that there is a lot of drawing because I tried to recreate this and if I draw it smaller it works. if i draw bigger then i get the error again.
can sombody help me?
EDIT: I found the whitelist setting pretty quickly, this solved the problem immediately
