what is the propoer way to make a revolve but along a path, rether than around an axis?
So, i want to make a doming around the path, i drew a profile, however the revolve tool only allows me to specify an axis, but i would need to specify a path too (highlighted). So revolve does not seems the way to go, can anyone advise on the best way to achieve what i try to do?
OR... just use the vertical line of your profile sketch as the axis!
https://forum.onshape.com/discussion/comment/50922#Comment_50922
Alternatively, you could use the Fill feature selecting the spline shape, then adding a point as a guide. Making either of these perfect can be fiddly though.
Btw for the Swept example above, I'm guessing one of the profile curves was swept along the other one, then the extra surface was trimmed away.
Independent Onshape Consultant | Industrial Designer
