Sweep solution needed
ricardo_raimondo
Member Posts: 66 ✭✭
I want to sweep Sketch 3 along Sketch 1, however, I get the error message shown in the picture.
Sketch 1 was build from a multipoint straight line.
Here is the shared link: https://cad.onshape.com/documents/20917420958441e4d4ab90de/w/af76defc13eef48f0f833802/e/16354cd317a98cf169c6732c?renderMode=0&uiState=6644a5bb24a2832b766f277b
Here is the picture
Here is the picture
On another note, that Sweep path is not ideal....unless you purposely want your Sweep Feature to have sharp break points along the way.
To fix this (if that is what you want), change that multisegment line to a Spline.
