Where is Variable Table (Part Studio)? Has it been moved, demoted?
john_e_bowen
Member Posts: 5 ✭
Hi. I'm in a Part Studio. I found I can click on the icon on the right hand side, to display the variable in table format, which is very cool. The reference is:
https://cad.onshape.com/help/Content/variable_table.htm
This works even when I'm in a sketch; quite handy. At least it was, last week. Now It seems to have disappeared. Instead, there are, from top to bottom:
Appearance Panel
Configuration Panel
Custom Tables
Hole Table
Did I miss something?
Thanks,
John
Appearance Panel
Configuration Panel
Custom Tables
Hole Table
Thanks,
John
_anton
Member, Onshape Employees Posts: 515
It won't show up if you're not in an editable workspace, or are in a particularly old Part Studio. If that doesn't help, I recommend filing a support ticket.0 -
jnewth_onshape
Member, Onshape Employees Posts: 89
Support may be able to assist you by forcing that document to upgrade to the newest version. If your copy and move solution doesn't work try opening a ticket and explaining the situation.0
I think I can copy or move my current tab to another workspace, to gain the added function. Thanks again!
