Sweep solution needed
ricardo_raimondoricardo_raimondo Member Posts: 61 ✭✭
I want to sweep Sketch 3 along Sketch 1, however, I get the error message shown in the picture.
Sketch 1 was build from a multipoint straight line.
Here is the shared link: https://cad.onshape.com/documents/20917420958441e4d4ab90de/w/af76defc13eef48f0f833802/e/16354cd317a98cf169c6732c?renderMode=0&uiState=6644a5bb24a2832b766f277b
Here is the picture
  • john_lopez363john_lopez363 Member Posts: 126 ✭✭✭
    edited May 2024
    Change your Sweep path (the multi-segment line you created) to normal lines...not construction lines.
    On another note, that Sweep path is not ideal....unless you purposely want your Sweep Feature to have sharp break points along the way.
    To fix this (if that is what you want), change that multisegment line to a Spline.
    This is what it will look like when using a Spline as the Sweep path.
  • ricardo_raimondoricardo_raimondo Member Posts: 61 ✭✭
    Thank you John. I will look into your suggestions. It looks that the basic thing I missed is that I cannot use construction lines to define the path. My fault
